Results 1 to 1 of 1
Thread: 2.7 Carrera RS engine complete with MFI pump and system
    I have for sale a complete 1973 Porsche 2.7 Carrera RS engine (type 911/83). The engine was removed from it's original car, kept in storage and has recently been stripped. The case is a blank but correct 7R type with all the heads and cam carriers date stamped the same 7-73. The cam's, the distributor, the rod's are all the correct type and number. The crank is in a good condition and will just require a polish. Finally the engine also comes with the complete Mechanical Fuel Injection system and the correct 019 pump.
    £14,000 as is.
    email nickmorf@googlemail.com or call 00447717 212 911
