Thread: Fuchs Wheel Truing tolerance
    Senior Member mar2mar's Avatar
    Feb 2003
    Los Angeles
    What is the acceptable lateral Truing tolerance for a 15" Fuchs wheel? I measured my wheels. The worst one is out of lateral trueness by approximately 0.55 mm.
    Aug 2011
    Eugene, OR
    Not sure of the spec off-hand, but to be measured properly, you should measure at the tire bead seat on the inside of the rim. Your results on the outside could easily be bogus due to prior rash repair, heavy-handed polish prep, etc.
    - Arne
    May 2005
    Oroville, CA
    That is not how you measure wheels. The outer lips are frequently very far off because of the finishing...or lack of, like the backs.
    They are measured at the centers of the bead contact for both hop and wobble.
    If you are using the hub on the car, you also need to check the hub for true first and adjust accordingly.
    The factory spec is max .045. The most important thing is a sharp...That should be addressed even if less than .025.
    We true to .025 on early and .020 on late Fuchs, but still address sharps because they will develop cracks...
    You can usually balance out a .050, except when it is both hop and wobble in the same area.
    Not a Fuchs but the only true checking photo that I could easily find (checking the hop, the wobble would have the dial indicator sideways..inside).
    (pay no attention to the type of wheel, just how it is measured)
    You may want to paint the tire area of your wheels to help prevent corrosion from moisture in the compressor air.JMHO
    H
