Results 1 to 10 of 18
Thread: Cibie base plates
    Cibie base plates
    Nov 2002
    San Dimas, CA
    The expert on Cibie lights is Gunter Hansele, who runs Aardvark International http://www.talbotco.com/
    Jim Alton
    Torrance, CA
    Early 911S Registry # 237
    1965 Porsche 911 coupe
    1958 Porsche 356A cabriolet
    Or just save a bunch of time via...
    http://www.ebay.com/itm/Porsche-R-ST...b4566e&vxp=mtr
    They're steel by the way...
    Peter Kane
    '72 911S Targa
    Dec 2010
    Southold, NY
    From the photograph, between the bolt spacing on your lights and the width of the flange on the hood bracing it should be fairly easy to scale out the size of the backing plate. It's not as if anyone is going to care about a few mm if you get the basic shape correct.
    Aug 2012
    France
    Have some, but not close to me. will try to get them next week.
    O-G 26 - Early911S 2407
    George, I think I have some at home with a NOS set. I'll get back to you when I get home. But you will be sleeping by then.
    Jul 2006
    Washington D.C
    Quote Originally Posted by ejboyd5 View Post
    But isn't there is also a downward "bend" at one of the rear corner?
    Andy (VA).
    Quote Originally Posted by flatsixcrazy View Post
    At two corners...
    Peter Kane
    '72 911S Targa
    Sunshine State
    George, I will also look down at my shop tomorrow. I think I have a spare I can measure.
    Senior Member larwik's Avatar
    Dec 2003
    Los Angeles, Ca
    Back Plates for Hood-Lights ......
    George...Here you go.../ Lars...
    P.S...the scan.pdf file is below the picture, if you can open it!...
    Plate Width:....~114MM
    Plate Height:...~120MM
    Plate Thickness:...1MM - Steel.
    Lars Wikblad...
    Early 911 "S" Registry # 527
    "R" Gruppe # 314
