Thread: Pair of Refurbished Parallel Window Regulators Dated 2/73
    Shift Knob Maker
    Oct 2004
    Marysville, OH
    These regulators where disassembled down to the two large rivets, all parts cleaned, refreshed and then reassembled. I have found that the original grease that was used is like glue after 40 years and I am using a modern Teflon based grease that should hold up better. I have installed new spring pivot pins made from 7071 aluminum and reassembled the crank gear assembly with hard rivets, not pop rivets. These are ready to install with a little grease on the plastic slide pivots. I did not "restore" these as they go inside the door and where raw originally, so no plating etc. I have installed another set in my own car and they operate great!! Price includes new rubber seals for the crank assembly - door contact point. These where in a coupe.
    $150 + some for shipping.
    PM for payment info.
    Thanks.
    Mark..
    window regulators
    Hi Marc, I'll buy your regulators.
    Thanks jerry landes 925 683 9754
    Hi again Marc.. I'm putting these in a 73 targa. Do you know if they are the same?
    thanks Jerry Landes
    Shift Knob Maker
    Oct 2004
    Marysville, OH
    Quote Originally Posted by Jerry Landes View Post
    thanks Jerry Landes
    They do have different part #'s listed but I am not sure what the difference is. I'm sure someone with more Targa expertise can fill us in.
    Mark..
    I will take them if the Targa ones are different as I need for a coupe
    Clyde Boyer
    Early S Registry Member #294
    TYP 901 Register Inc #6
    Shift Knob Maker
    Oct 2004
    Marysville, OH
    These have been SOLD.
    Mark..
