Results 1 to 7 of 7
Thread: Early Recaro seat ID help needed
    Senior Member ghalperin's Avatar
    Apr 2014
    Newport Heights, CA
    I just had this shipped from Germany and need help identifying what I believe is a early Recaro seat.
    There are rows of small screws and the shell sides and back are covered in vinyl.
    Thanks in advance for any help.
    Name:  IMG_0110 (Small).JPG
    Name:  IMG_0112 (Small).JPG
    Name:  IMG_0113 (Small).JPG
    Name:  IMG_0102 (Small).JPG
    Name:  IMG_0105 (Small).JPG
    Glenn Halperin
    Early 911S Registry Member #2956
    Senior Member uai's Avatar
    Jan 2011
    Horb a.N. Germany
    Hi, I'd say it's a lookalike but not a Recaro.
    Hope you didn't pay Recaro money for it.
    Cheers
    Uli
    Apr 2014
    Newport Heights, CA
    I got a good deal on it, but I'd like to know exactly what it is. Even if it's not a Recaro, it looks pretty old, has great patina and my XL 6'2" 235 lb. frame fits well in it.
    Glenn Halperin
    Jan 2011
    Horb a.N. Germany
    Hi Glenn,
    just a little explanation what I can see.
    The seat base clearly looks like 4 legged Recaro. The Recaro sliders had different mounting holes - so never been on a Recaro Slider.
    That type of seat had initially no headrest reception when they were introduced they were screwed in.
    Gelcoat finish doesn't look like recaro - shape of the backrest too.
    Cover Material also not recaro. The screw stuff isn't recaro too.
    What would be interesting is the headrest stuff. Can you take off the seat padding and take a photo of the headrest reception.
    Cheers
    Uli
    Glenn, this is the factory parts book showing the Recaro
    Ernie W
    member of Early 911S Registry
    Apr 2014
    Newport Heights, CA
    The padding is well attached and I don't want to risk damage to it by trying to look under it. On a side note, it weighs approx. 12 lbs.
    Glenn Halperin
    Apr 2014
    Newport Heights, CA
    Head rest
    This is the mismatched head rest that came with the seat.
    Name:  IMG_0109 (Small).JPG
    Name:  IMG_0107 (Small).JPG
    Name:  IMG_0108 (Small).JPG
    Glenn Halperin
