Page 3 of 3 FirstFirst 123
Results 21 to 24 of 24
Thread: Bearing/Spacer alignment issue
  1. #21
    First, realize that taper roller bearings need a slight preload, there is a factory procedure in the shop manual, but I don't do it that way as if not very careful you can bend the bearing cage. With the brake pads pushed back, so no pad drag to interfere, I over tighten the spindle nut and rotate the hub to fully seat everything. Then back off spindle nut until you fell free play when rocking the hub by grabbing at 12 and 6 o;clock position, now slowly t5ighten spindle nut until you just reach the point of no free play, from that point tighten the spindle nut about a 1/16th turn further, there should be no free play and the bearings will be slightly preloaded. When rotating hub (pads still back) it should rotate freely but NOT free wheel much.
  2. #22
    Senior Member Dezzmo's Avatar
    Nov 2006
    Rhode Island
    Quote Originally Posted by zenithblue71T View Post
    Hi Ed,
    Where can I find a step by step process to tighten my front wheel bearings? I looked in Hayne and 101 projects but no luck. The search on this forum led me only to here. I actually heard you tighten all the way then back off the spindle nut a quarter turn. If you over tighten, you fry the bearings.
    http://www.pelicanparts.com/techarti...eplacement.htm
    When I did my bearings I followed the instructions in Waynes book which is pretty straight forward James. Just scroll down to figures 16 and 17 and it will show you how it's done. HTH
    Tim G
    Early S Reg #1017
    RGruppe #663
    73 911T 3.2
    00 Ducati 996 Track Rat
    01 Ducati S4 Monster
  3. #23
    Nov 2006
    Rhode Island
    Ed beat me to it by 10 minutes
    Tim G
    Early S Reg #1017
    RGruppe #663
    73 911T 3.2
  4. #24
    Dec 2009
    Copenhagen, Denmark
    Thanks guys, much appreciated!!
    James Hurst #1638
    R Gruppe #514
