What gauge of wire is used and where is the best place get it?
Glenn Halperin
Early 911S Registry Member #2956
I find that the best holes in my fingertips come from the use of stainless lock wire from Aircraft Spruce in 0.020"
In addition to twister pliers a tetanus shot is required.
................... I love it.......In addition to twister pliers a tetanus shot is required.
Thanks for helping resurface the puncture wound flashbacks. BTDT.
Glenn Halperin
I've measured quite a few pieces of OEM wire an I use 0.023" dia, black, annealed, oil-finished wire for restorations. But for the bulk of my work I use Type 302 stainless safety wire at 0.025" dia.
McMaster-Carr is my playground for most parts, tools, etc.
Paul Abbott
Early S Member #18
Weber service specialist
www.PerformanceOriented.com
info@PerformanceOriented.com
530.520.5816
Paul,
Thanks for your input. I measured and after trying to take out the kinks, I came up with 0.021 for the wire on it now. Most likely 0.020.
They've been apart before, just not in the last few decades.
Some of the wires are pulling the bolt the wrong way. Although none were loose.
Can you show us the correct way to tie the bolts?
Glenn Halperin
OEM wire installation was not per typical aircraft installation procedure in that the wire should tighten as the bolt loosens. The wire in the photo looks pretty much per OEM installation with the loop going through the hole in the body first, a couple of twists and then through the hole in the fastener's head.
I just re-measured some wire and also saw 0.020" dia.
Paul Abbott
Early S Member #18
530.520.5816
