Results 1 to 2 of 2
Thread: Use of 1974 hubs on swb brake conversation
    Oct 2010
    Denmark
    Hi
    I´m doing the front 3" brembo caliper/vented disk conversation on my early 1967 swb #306801
    using 20mm vented disk od 282 mm.
    I have some refurbished hubs 47 mm. with new bearings 911.341.605.4R from 1974-89
    can I use them for this conversation , and do I have to change the 17 mm.spacer pressed on the spindle 901.341.681.00 to later type 21mm 901.341.623.00?
    rg.Lars
    Jan 2011
    DFW TX
    I don't the answer to your spindle question but I do know you will have trouble with your wheels..
    74-on front hubs have a hub-centric boss and I don't think pre-74 wheels will fit.
