Just listed my '72 911T Hot Rod on Ebay. This was built from an extremely solid car from the ground up. Very quick, sounds great, solid, sound car that you can drive anywhere
http://goo.gl/cJl5mV
1972 Porsche 911 T RS/ST/S Tribute
VIN # 9112102742
Bahia Red, Spies Hecker 2 stage applied June 2013
Paint 8.5-9.0 stars out of 10
RS gas-welded steel flares
Oil door removed and oil tank moved to rear
Unknown Chassis mileage
Very solid, no rust car
Very quick, great-sounding, fun-fun car
MOTOR- under 5,000 miles since rebuild June '14
1983 ROW 911/930 3.0 motor
3.2 short-stroke EBS Nickisil Barrels
JE 9.7:1 Pistons and rings
Large Valve Head ported, new valves, guides, seats
Racing Valve Springs, titanium retainers
WebCam 464/465 Cams
Raceware Rod bolts
New 46mm PMO Carbs w/ K&N & Rainhats
MSD Ignition
Hershon IAE Recurved Distributor
SSI Headers and Exchangers
M&K Sport 911R-type Muffler
GEARBOX/SUSPENSION
915 Gearbox w/WEVO Shifter, new shifter bushings & coupler
Choice of Fuchs 7” X 15” - Fronts, 8” X 15” - Rears
or
Group 4 Campagnolo PAG wheels in satin gold 7's & 8's
New Falken 205/55-15 fronts, 225/50-15 rears
SC Alloy Trailing Arms
964 4-piston front calipers and ventilated and drilled rotors F&R
Turbo tie rods, new bushings and bearings all around
New Bilstein HD F&R shocks
Elephant front strut brace
Just aligned and corner balanced October '14
OTHER
Gas-Welded RS-type rear flares
RS Front bumper with Porsche OE Oil Cooler
OE RS Touring Trim
Optional painted fiberglass ducktail, w/grille ready for bolt on
Hella H4 Headlights w/upgraded relays, wiring, LED Signal bulbs
Dynamat floors/firewall
Period Vintage Racemark Wheel with Zuffenhaus raised hub
Later SC gas tank
Alloy spacesaver spare, unused
INTERIOR
Sport Classic Seats Leather and VW GTI Mk VI Plaid inserts
RSA Door Panels
Original rear seats in great shape
Blaupunkt Toronto Bluetooth w/Pioneer 2-channel amp
Removable Vintage suitcase JBL speakers
New Lightweight Perlon Carpet set
Black/Red Cocoa Mats
Updated electric Speedo
Working clock
Later 7200 Redline Tach
Black Headliner, great shape
Will add under car pictures this weekend, clean and dry as the top
