Thread: Need help with fender well finishes
    Question Need help with fender well finishes
    Thanks for your help, in trying to restore to factory specs my 73 coupe, my fender-wells have a black finish over the factory undercoating (tangerine) is this correct or should be Tangerine?
    Thanks so much for your help!
    Also if anybody knows of a reference book that describes correct finishes I would certainly buy it.
    slicktop,
    Your '73 should have body color in the fender-wells; and in the trunk, and the engine compartment.
    The amount of color that was sprayed varied, with the trunk usually getting the lest....
    Lots of threads on this.... search is your friend
    Hope this helps
    Thanks Chuck I appreciate your help,I was 90% sure it was but nice to have that confirmed.Would like to find a reference book that defines all the different finishes, options,and basically how the cars left the factory?
    Mark
    Feb 2012
    Edmonton
    I found these pics helpful when I started restoring one of my '73Ts
    https://plus.google.com/app/basic/ph...brviu&sview=20
