Engine N° 907093 : type 901/05
fast road/rally engine , 180-190 hp ,fully rebuilt by PORSCHE experienced specialist
engine sand-cast crank case cleaned and line bore checked & measured.
Oil By Pass modification and larger oil pump (4 ribs- carrera 3.0)
crankshaft polished and balanced
2.2 S( stiffer) nitrated connecting rods ( weighted 727 gr)
All new bearings ( main & connecting)
new distribution ( chains & wheels)
camshafts ( new) made to "S" profile
forged rocker shafts & arms(lighter & stiffer)
new MAHLE pistons and cylinders from 2.0S with new rings
Big ported heads ( 36 & 35 mm)
All valve guides& seats new
All valves brand new ( 42 & 38 mm)
Flywheel lightened & balanced (with cranksahft & clutch mechanism)
Distributor Aluminum type 07( 2.2S)
All sheet metal, Fan, and so on powdercoated
some Built on parts new gold plated
WEBER 40 IDS , fully rebuilt like new with K&N air filters
brand new complete clutch system ( mechanism & disk)
this engine has not run after rebuilt and has been properly stored in a dry and heated workshop.
It can be picked up at my address or shipped for buyer cost & risk.
Asking € (Euro) 25000 , reasonable offers will be considered
As I don’t know how to insert Pics , they are available on request : PM or e-mail at:
jean-dominique.julia@wanadoo.fr
