Results 1 to 8 of 8
Thread: Early electric antenna questions
    Please see photo below
    Is this appropriate for a 67, ( I think it is,) Any idea of value?
    Skip
    Here is the photo
    Senior Member SEBB's Avatar
    Mar 2012
    FRANCE
    Can you give the serial number engraved on the aluminum case?
    Thanks you
    This is all I can find:
    Type 6000F751
    Werk-Nr 322167
    Does that help?
    Aug 2009
    SF Bay Area
    Quote Originally Posted by CarmelSkip View Post
    Skip
    I would bet that Joris K. would know the answer. He is 718RSK on this forum.
    Joris, where are you?
    Jim
    Hey Jim,
    Had a hard time finding this thread among all the auction result threads.......
    Skip,
    As Jim knows I recently moved and have not unpacked all my stuff yet. As such it is hard for me to look up the Hirschmann number for the electric antenna used on the SWB cars. The workshop manual gives some clues however. The antenna shown I believe is a Hirschmann AUTA 6000 D series antenna and not the F series shown in your picture. This does not mean that the antenna shown by you will not fit. It was however likely never intended to be installed on a Porsche.
    I do not know what your intentions are. If you want to be authentic I would say look further. If you want to install a period electric antenna on your car I would ask the seller for some key dimensions and figure out if you can make it work.
    Good luck,
    JK
    Aug 2009
    SF Bay Area
    Joris
    Gettin' a bit chippy ain't you? You aren't old enough to be that grumpy!
    Ciao
    Jim
    Thanks gentlemen. It seemed that the part that shows above the fender was very similar to "correct" manual antennas that I had seen on SWB cars.
