Results 1 to 9 of 9
Thread: what does a 1964/1965 engine mounting 'sword' look like?
    Senior Member pss's Avatar
    May 2014
    Netherlands
    I have 2 engine mounting 'swords' of different type. In restored 1964/1965 cars I have found both types, but I do not know which one is correct for which production period.
    I saw the first one below on a 1964 car. This type has an edged side for extra stability/strength. The second one I have seen on 1965 cars and is also on my 1965 engines and looks more simple.
    What does yours look like?
Size:  149.3 KBName:  IMG_1606.JPG
    member 2971 Jacques
    911 March 1965
    912 April 1965
    911 May 1965
    964 RS clone (one of many)
    964 Targa original Dutch police car (one of 45)
    964 Turbo 3.6 (one of 1450)
    993 S Vesuvio (one of 250)
    Senior Member RennTyp's Avatar
    Apr 2006
    Oxford, UK
    The second one ( without the turned edge) is correct for 64 and 65 cars. They often broke which is why you see cars with the later version that was redesigned to be stronger.
    Early 911S Registry #888
    Quote Originally Posted by RennTyp View Post
    I would love to see that.
    Where did they break? Do you have a picture of one?
    Richard
    Nov 2002
    San Dimas, CA
    The one in my 1965 car (301382) looks like the bottom photo,
    Jim Alton
    Torrance, CA
    Early 911S Registry # 237
    1965 Porsche 911 coupe
    1958 Porsche 356A cabriolet
    The folded edge is 67-
    May 2014
    Netherlands
    Txs. good info. Seems I need to find one more of the simple type.
    Cheers, Jacques
    member 2971 Jacques
    911 March 1965
    912 April 1965
    911 May 1965
    Apr 2006
    Oxford, UK
    Quote Originally Posted by preS View Post
    Richard
    They break at the narrowest point just next to where they bolt to the chassis. I have one - will be back with a photo later...
    May 2014
    Netherlands
    I found more 'flat' engine swords in the lower picture, but they have a different shape than mine. Mine is first picture, the ones I find are the bottom 2.
    - Mine is a rhombus or diamond shape flat sheet metal; the other 2 are straight at the top.
    - mine has relatively large hole in the middle versus the other 2, of which each hole is also different again
    Who can tell me which period these 3 different swords are?
    Name:  engine sword2.jpg
    Name:  engine sword.jpg
    member 2971 Jacques
    911 March 1965
    912 April 1965
    911 May 1965
    May 2014
    Netherlands
    Solved the issue, the lower 2 in post 8 are 912, the correct 1965 911 is the upper one in thread 8.
    member 2971 Jacques
    911 March 1965
    912 April 1965
    911 May 1965
