Results 1 to 8 of 8
Thread: 1972 model : zinc plated white / yellow - what parts ???
    Hello,
    is there a database where I can find such informations ???
    On the french forum, we are "fighting" for yellow vs white
    thanks
    fred ©
    If you must disagree, I'd replace zinc with cadmium for improved corrosion resistance. I believe yellow was the fastener of choice as manufactured?
    Sherwood
    Quote Originally Posted by carrera79 View Post
    Hello,
    thanks
    fred ©
    Fred, by 1972 the Factory was using a zinc plating with a yellow hexavalent chromium conversion coating. CRVI tends to kill the liver so it is no longer in use in many areas (It would surprise me if it were still allowed in EU)
    These days, all we have is trivalent chromium, so the appearance is slightly different, but it should be yellow for that year.
    It is more important to me to get the correct fasteners with the correct headmarks than the precise yellow color of the plating. . . one would lose points for 8K where it should be 8.8 and |o| (a common Taiwan headmark) where it should be VERBUS, for example.
    Hope this helps!
    There weren't a lot of clear zinc (silver) parts by 72. The most obvious are MFI injection pipes and holders. Gled
    Hood latches and door latches?
    Jul 2006
    Corvallis, OR
    The hood latch and door strikers were silver.
    72S, 72T now ST
    thanks for answer, i know the REACH problem with Cr6 (and now I use Cr3 instead).
    Latches are white, but other parts ???
    all brake parts ? yellow ? black ?
    fred ;-)
    Senior Member SpawnyWhippet's Avatar
    Mar 2013
    San Francisco Bay Area
    Has anyone tried the various home plating kits available? I am thinking of ordering one, but would like some input on which kits work the best or provide the most accurate color.
    Member # 2899
    1972 911T
    2004 996 C4S
    2001 996 Carrera
    2008 Cayenne S (sold)
    2004 Cayenne Turbo (sold)
    2009 997 cabriolet (sold)
    2002 996 Turbo (sold)
    1998 Boxster S (sold)
    1997 993 cab (sold)
    1989 911 3.2 Carrera (sold)
