Results 1 to 7 of 7
Thread: Drilling template for dead pedal
    Sep 2012
    Philadelphia, PA
    Question Drilling template for dead pedal
    Anyone out here have a drilling template for the dead pedal?...TIA
    Serge
    Early S Registry #2457
    Aren't they welded?
    Richard
    Aren't they welded?
    They could be, however the factory part came with 4 holes for mounting...
    I mounted mine with 4 stainless screws and nyloc nuts through the wheel well...
    Sorry, I have no template
    If it's a coupe there is a pretty good 'sweet spot' on the bulkhead... if it's a Targa, I hear it's a little different story...
    Apr 2004
    35,000 ft
    the dead pedal IS the template....hold it up to where you think it should go....(make sure you won't be drilling into anything important) and drill
    Here's what's on the Sierra Madre website:https://www.sierramadrecollection.co...tallation5.pdf
    rb
    Nice Roger B - that promotes you to Senior Member - better advice than others above you and they only have 8k+ posts
    Early 911S Registry #750
    1970 911E - The Good Stuff
    2001 Toyota Landcruiser
    Sorry Chuck, the factory part was welded in place. I decided to include the holes, and rounded corners when I began to produce them. I drew the installation instructions and posted them on my sale thread since the beginning. SM uses my drawing.
