Thread: 1969 911S transmission - help to find the car it belongs to?
    I've got a 1969 911S ( I think ) 901/13 transmission. I've googled the serial number but no dice. anyone have an idea how to find the correct car? I'd prefer to see them re-united if possible. thanks much, Don.
    type number 901/13
    serial number 7196257
    Apr 2012
    Simi Valley Ca
    My April build 69S is has S/N 7196128, and the chassis is almost 3/4 of the way thru the build, so that would place your trans as a late 69. Probably in the range of chassis #119 30 1200.
    Bob B
    Quote Originally Posted by haycait911 View Post
    I've got a 1969 911S ( I think ) 901/13 transmission... type number 901/13... serial number 7196257
    This was the standard 5-speed transmission for both '69 911E and S models, and optional 5-speed for a 911T.
    There was no 911S-specific transmission in 1969.
    Jon B.
    Vista, CA
    Aug 2009
    SF Bay Area
    type number 901/13
    There is no way to find the car it came from, other than going through every kardex, by hand, for 69 911s (not just Ss) and looking for the trans number. Good luck with that!
    Jim
    PS: I guess you could eliminate the first few hundred 69 911s that came with transmissions with "die cast" housings
