Results 1 to 10 of 15
Thread: rubber/platic liner under aluminum door threshold
    Jul 2014
    Long Island NY
    Wondering if the factory put anything underneath the outer aluminum door sill plate (71 targa) or did they just rivet this directly over the painted sill/rocker.? My car was repainted somewhere long the line and now I'm reassembling it. Thx in advance
    Senior Member moito's Avatar
    May 2013
    AUSTRIA (tu felix)
    removed them from an untouched my 70 car last week....nothing underneath.
    Quote Originally Posted by Jrsully View Post
    Not metal rivets, plastic ones, and as said nothing underneath.
    Clyde Boyer
    Early S Registry Member #294
    TYP 901 Register Inc #6
    Nov 2006
    S. F. Bay Area
    Quote Originally Posted by BOYER73S View Post
    Yes, white plastic, all repros I've seen are super-weak. Any good ones around??
    Yes, nothing under alu trim.
    Brian
    S Reg #1032
    Jul 2014
    Long Island NY
    Thanks to all, also interested in correct plastic rivets
    Sep 2006
    San Francisco
    I believe the plastic rivets are still available from Porsche, although these days that doesn't guarantee that they aren't poor repros as well. No personal experience, but they do show as available.
    Jeff Jensen
    May 2013
    AUSTRIA (tu felix)
    they are still available at porsche but pricy...they are transparent and not white....if you can not get them anywhere in the us you can find the same ones porsche sells on ebay.de search for "porsche 914 spreizniet
    i installed the trim with those rivets today.
    What tool if any do you use to install them? I have a bag of the ones Porsche sells and they end up bending or distorting when I try and push the pin in.
    I used some white aluminum rivets which appear almost like the original white plastic ones.
    Nov 2006
    S. F. Bay Area
    Me too, as if the 'pin' was made of rubber!
    Brian
    S Reg #1032
    I start the pin in with a small pliers, that way I can 'support' the pin, then give it a final tap to seat it.
