Results 1 to 7 of 7
Thread: FS: 1956 356 Short Block w/Crank & Rods
    Banned
    Jul 2013
    Louisville, Kentucky
    FS: 356 Short Block w/Crank & Rods. 1956 3rd Piece
    For sale:
    Porsche 356 short block with crank & rods. Spins freely.
    The case numbers on the left & right side do not match the third piece.
    Right: 562
    Left: 562
    Front: 789
    Engine number on third piece is 62908. This piece is a 1600 (Type 616/1), part of range 60609 to 63926 and was fitted to the following cars.
    This engine was originally fitted to a car as follows:
    •1956 (built 1956) T1 A cabriolet (Reutter) with a serial number between 61070 and 61499.
    •1956 (built 1956) T1 A coupe (Reutter) with a serial number between 55391 and 58311.
    •1956 (built 1956) T1 A Speedster (Reutter) with a serial number between 82001 and 82850.
    The other two pieces of the case are stamped as a 1600S case.
    $1495.00 plus shipping & pay pal fees if applicable. Checks are welcome w/forum history.
    Consider a core. No visible cracks anywhere.
    PLEASE EMAIL, TEXT, or CALL. I DO NOT CHECK PMs OFTEN.
    Thanks!
    Robert Liberty
    rliberty@911sportscars.com
    502.533.4996
    So I may be wrong here, but if the 3rd piece with the engine number on it does not match the actual case halves is it really a 56 motor? Are there any date casting stamps on the block itself they indicate a 56 motor?
    Banned
    Jul 2013
    Made an adjustment to the description. Not sure if there is a date casting stamp to indicate a 56 engine. I could be wrong as I am NO EXPERT, but as you will see in the pictures the case has a 1600S stamp. This stamp should indicate that it is a 59 or later case. Only the front piece is for a 56.
    Banned
    Jul 2013
    Actually...maybe the 1600S started in 1957 looking at the 356A.com site.
    Aug 2009
    SF Bay Area
    Quote Originally Posted by rliberty View Post
    The number on the top of the case indicates that it was manufactured sometime in late 56. I really like the work some PO did to remove the gland nut.
    BFH and a chisel............some quality work there!
    Yes, the 3 pieces are not matching but they are not too far apart in age.
    Jim
    Banned
    Jul 2013
    Thanks for the info Jim. I appreciate it.
    Banned
    Jul 2013
    Another Pic
    Here is another picture...Thanks.
