Thread: '72 911T - No gaskets for MFI throttle bodies to intake ports?
    Senior Member SpawnyWhippet's Avatar
    Mar 2013
    San Francisco Bay Area
    I am bolting my MFI throttle bodies back onto my rebuilt engine and noticed that unlike the exhaust ports, there were no gaskets or seals of any kind between the throttle body and cylinder head on my intake ports.
    I am guessing that this was not correct.
    I checked in my copy of PET and there appears to be 2 gaskets (901 108 391 04) and an Intermediate flange (901 108 131 00) between each throttle body and the intake port, but Pelican said it was for 'Zenith carburetor manifolds'.
    Can anyone clarify if I need to order just a set of 6 gaskets, or 12 gaskets and 6 intermediate flanges?
    Member # 2899
    1972 911T
    2004 996 C4S
    2001 996 Carrera
    2008 Cayenne S (sold)
    2004 Cayenne Turbo (sold)
    2009 997 cabriolet (sold)
    2002 996 Turbo (sold)
    1998 Boxster S (sold)
    1997 993 cab (sold)
    1989 911 3.2 Carrera (sold)
    On MFI you just use the 6 gaskets. Are you saying there were none when you disassembled the engine?? It's amazing the atrocities that can be done to those engines,,,,and they still run!!
    The Zeniths used a phenolic insulator block to prevent fuel from boiling in the carbs. That uses a gasket on either side as illustrated.
    Obviously with MFI that is not a concern! So just six gaskets between head and TB. Don't forget your magnetic tool, this is used to retrieve the nuts you drop down the intake ports during installation!
    Mar 2013
    Don't worry, I'll leave the masking tape across the ports so nothing can fall in while I bolt the throttle bodies on. ;-)
    Member # 2899
    1972 911T
    2004 996 C4S
    2001 996 Carrera
    1997 993 cab (sold)
