I have a dated 73 plastic tank to fit into my 73 car , working out the brackets to hold it i find the front is wayyyy off the bolt hole in the y support. Its far to forward. what am i missing ?
John Gausden
Auckland, New Zealand
(shipping carson,CA)
Early911nz.org
ST-Classic.com
ST-Classic Facebook
You have to drill a new mounting hole for that front bracket. I think that's the problem you're describing?
so it doesn't attached to the existing hole in the y support. well that makes sense i guess . so my next question would be , the car has the mounting holes for rs brackets in the vin panel so why not the front trunk floor panel? this car is a mystery.
John Gausden
Early911nz.org
ST-Classic.com
ST-Classic Facebook
That's normal,,,the holes for the nut plates in the trunk floor were there in all 73's, but not the front bracket hole.
see the pic of my RS with hole for bracket
Clyde Boyer
Early S Registry Member #294
TYP 901 Register Inc #6
thats great , last question the top bracket mounting plates are rivited to the panel , std rivets or rose head ? whats period correct
John Gausden
Early911nz.org
ST-Classic.com
ST-Classic Facebook
What I call normal rivets is what the RS had and pretty sure they were factory
Clyde Boyer
cheers will go with that
John Gausden
Early911nz.org
ST-Classic.com
ST-Classic Facebook
