Thread: RS plastic tank venting set up - pics please
    Sep 2008
    Auckland , New Zealand
    fitting a 85ltr RS plastic tank , can someone give me the venting set up that should be on this tank in a 73 , cheers
    John Gausden
    Auckland, New Zealand
    (shipping carson,CA)
    Early911nz.org
    ST-Classic.com
    ST-Classic Facebook
    Here you go RS #197
    Goes from tank to plastic charcoal canister via plastic line (the orange coloured plastic) up under dash than back down from the cannister to a hole near battery box and vents into guard area.
    Clyde Boyer
    Early S Registry Member #294
    TYP 901 Register Inc #6
    Sep 2008
    what would be the issue if i took the vent line from the filler , y joined to the tank breather then took both to the fender expansion chamber with that just venting outside ? make it much cleaner
    John Gausden
    Early911nz.org
    ST-Classic.com
    ST-Classic Facebook
