Results 1 to 2 of 2
Thread: how to separate front sway bar bushing from 3 hole tri plate?
    Oct 2010
    Denmark
    Can anyone explain me how to get the sway bar square out of the bushing in the 3 hole plate? and how i will get the new bushing over the square again when the whole set have been refurbished?
    rg.Lars
    #2264 classic's Avatar
    Nov 2004
    Gold Coast.
    It just pulls off. The rubber has just gone hard, I had to get I drill and Swiss cheese mine to get them to collapse enough to pull off.
    The replacement rubber bush has a slit in it, so it just slides over. You'll probably have to use longer bolts to get it started compressing the rubber, then just replace with the correct size.
    Hope that helps.
    Tony
