Thread: 70 911E targa suspension
    Junior Member birdleg's Avatar
    Nov 2014
    Philippines
    Question 70 911E targa suspension
    How do I find out what suspension the car came with? hydropnuematic boge, koni, etc? The shocks on the car now do not match each other and I can't make out what they are cause they are covered in heavy grime and are unusable. I know its not original but I want to get the turbo tie rod kit from pelican parts to make the cars steering better since the car will be used frequently. Just wondering what suspension matches with this kit without any modification.
    Pat Hesse
    1970 911E Targa
    https://www.facebook.com/Monkeywrenchph
    Feb 2003
    Corpus Christi, Texas
    Pat, the Turbo Tie Rod Kit won't have any affect on what suspension you use. The rear shocks are easy, do you know what front struts are on the car now? Generally Black is Boge, Red/Orange is Koni and Green is Bilstein. No telling what's been changed on the car over the years and it's not unusual for someone to have painted Boge struts red to look like Koni's. If you're going to replace the complete strut housing (not usually necessary as you normally just replace the insert) then you'll have some additional options.
    Jason Burkett
    Paragon Products
    www.paragon-products.com
    Early 911S Registry #428
    R Gruppe #375
    1973 911S
    1972 911T
    1974 914 Limited Ed. Blk/Yellow
    1989 944 Turbo
    1993 968 Turbo RS
    1967 Shelby GT500
    1968 Shelby GT500 Conv.
    2010 VW GTI, Daily Driver
    Nov 2014
    Philippines
    Awesome thanks! front struts are both orange but the rear has one black and one orange lol
    Pat Hesse
    1970 911E Targa
    Feb 2003
    Ok, sounds like original Koni housings which will take the Koni 86-1647:
    http://www.paragon-products.com/prod...ni-86-1647.htm
    Bilstein won't make an insert for the Koni strut and although KYB does, you don't want to go there
    On the rears you can do pretty much whatever you want but if you want to match the Koni fronts you'll want to use the Koni 80-2088:
    http://www.paragon-products.com/prod...ni-80-2088.htm
    Jason Burkett
    Paragon Products
    R Gruppe #375
    1973 911S
    1972 911T
    1989 944 Turbo
    1993 968 Turbo RS
    1967 Shelby GT500
Tags for this Thread
