Thread: 1972 2.4s oil lines, help needed!
    Hi, I'm restoring a 2.4S but lost all my pictures from dismantling.
    I'm looking for pictures off the oil lines under the rear fender.
    Wich goes where on the console etc...
    Senior Member majordad's Avatar
    Dec 2012
    Cork , Ireland
    Page 22 of the Rennlist Restoration of my 72S might help?
    http://rennlist.com/forums/911-forum...or-not-22.html
    Majordad, that's almost what I need, still need to figure out wich off the oil lines goes where...
    Quote Originally Posted by lowfastbus View Post
    Does this help? Note that I am using a thermostat in the factory oil filter console and connecting it up to front mounted oil coolers. But it should give you an idea of where to connect each line (console to oil cooler, motor, and oil tank).
    http://forums.pelicanparts.com/porsc...ml#post8049166
    - Josh
    - '72 911t
    - '81 euro SC
    Found it out:
    Top one comes from oil cooler
    Bottom one from engine
    Front one from oil tank
    Thx for the links!
