Thread: FS: 1973.5 911T Coupe Matching Numbers RS tribute/clone
    SOLD! Thanks for the interest.
    Restored ‘73.5 with no rust, no leaks and only 300 miles on it since engine was rebuilt (partial). VIN: 9113102580, original 2.4 CIS (Bosch K-Jetronic) engine #6134761. I’m the 4th owner, the previous owner had it for 26 years. Excellent Viper Green paint (windows out, trim off) done in 2009 and driven sparingly since. Per the COA, the orignal color is silver. New front suspension pan, new floor pan (front half). Fiberglass duck tail, fiberglass front RS¬ style bumper and fiberglass front fenders, H4 headlights. Car starts easily, drives and shifts beautifully. Original 15” Fuchs (date stamped 1/73). Newer carpeting, headliner, shocks, SS brake lines, rebuilt calipers. Has updated Carrera chain tensioners and turbo valve covers. New lenses all around, new rubber window seals, new rear bumper deco trim. Engine was completely dismantled, cylinders honed, new piston rings, cleaned and adjusted all valves, installed new valve seals, discovered that valve guides are “newer”. New Cam chains, new bearings. While apart, discovered that the engine has the following “newer” parts: oil thermostat, cold start injector, warm up regulator, throttle position switch, flexible fuel lines. All injectors were removed, cleaned and bench tested, they’re all spraying evenly. We resealed engine with complete gasket kit. Throttle body inspected/cleaned. Cylinder heads were inspected and powder blasted. Fuel distributor disassembled, inspected, cleaned and installed new “O” rings. New Bosch fuel accumulator, new fuel pump, new spark plugs. Owner’s manual, maintenance book, tool roll, jack and spare wheel/tire are all there. Car is located in NH. 001.jpg002.jpg003.jpg004.jpg005.jpg
    May 2009
    West LA
    Registry Member #1583
    Yes, it's come a long way in a year... engine overhauled, rust repaired, interior brought back to "original".
    ...and the price is???
    Quote Originally Posted by mjk911 View Post
    See the very end of the text...
    Peter Kane
    '72 911S Targa
