Hi,
I saw that this morning; travel kit for 911 from Sierra ; does someone can comment on accuracy or quality ?
http://www.sierramadrecollection.com...detail&p=13468
Thanks !
JD
Hi,
Thanks !
JD
1970S Coupe, Blood orange #1436
1965 Coupe, Dolphin gray #1506
R Gruppe #647 ; S Registry #1666
Expensive seeing as it's all reproduction... but it looks nice...
Member #1616
Is the color of the bag correct? I´ve only seen reference pics of different kits, non in real life. But as I remembered it from the pics the bag seemed to be almost dark grey and this one seems to be light grey.
Nick
Is a 69 the same if so I can post a picture of my Nice Original bag?
I think travel kits are cool, but over rated at these prices. Its just a silly bag with some common spare parts, looks like all of the parts included are modern production. Victor Reinz crappy gaskets. I see they reprinted the Porsche part number decal, of course they could have re-produced the right decal not the later burgundy one that would not be on a original kit.
I could make this myself for much less, and could probably set it up with parts that you would actually need on a journey. My travel kit is usually a cardboard box full of stuff and I am not afraid to drive thousands of miles no matter how rare the car is.
I have a complete real 70/71 one. I recall the burgundy decal was on, but with the plastic cover, not on the bag.
Interior is light grey, I dont know if they came light blue.
Yes, expensive&overrated maybe but the real deal is hard to get. Its now more a collector object as you destroy its value once you would use it.,,
Registry member No.773
I had a bag that was dark blue.
My 911 came to me (back in 1997) with a travel kit bag masquerading as its toolkit. If that was an original 1965 bag it was a light gray-green.
If you wish, you can buy a reproduction bag from Autos International. The reproduction bags have slightly lighter buckles. The early hardcopy parts manuals for 911s list the contents. Here's the list for a really early car with Solex carburetors and center-lubricated camshafts:
901.721.901.02 Ersatzteile-Tasche mit Inhalt für Fahrzeug Typ 911, bestehend aus:
Travelling kit for type 911, with contents, consisting of:
- Sac pour pièces détachées pour le moteur type 911, avec contenu, comprenant:
- Borsa dotazione ricambi per tipo 911. con contenuto, corn prendente:
- bis Programm “A”/ up to programme “A”/ jusqu’ au programme “A”/ fino al programma “A”
- 616.721.902.00 Tasche - Bag - Sac - Borsa 1
- 644.721.013.00 Plastiktasche mit Sicherungen - Plastic bag with fuses - Pochette plastique avec fusibles - Borsetta di plastica con valvoline 1
- 901 .108.964.00 Membrane für Kraftstoffpumpe - Diaphragm for fuel pump - Membrane pour pompe à essence - Mern’Drana per pompa 1
- 901.602.960.03 Unterbrecherkontakt (Satz) - Contact breaker (set) - Rupteur (jeu) - Ruttore (serie) 1
- 999.170.010.90 Zündkerze - Spark plug - Bougie d’auumage - Candele dl accensione BOSCH W 250 P 21 3
- 901.105.901.00 Ventilfeder innen und außen, Satz für ein Ventil - Outer and inner valve spring. for one valve - Ressart de soupape extérieur et intérieur pour une soupape - Molla esterna ed interna per una valvola 1
- 901.105.417.00 Geteiltes Kegelstück - Valve keeper - Demi-bague d’ appui Pezzo conico in due parti 2
- 901.104.193.00 Ventilabdichtung - Valve seal - Joint de soupape - Guarnizione valvola 1
- 901.105.370.02 Ventileinstellschraube - Valve adjusting screw - Vis de réglage de soupape - Vite registro punterie 2
- 999.034.005.00 Mutter für Einstellschraube - Nut for adjusting screw - Ecrou pour vis de réglage - Dado per vite registro 2
- 901.107.176.00 Ölablaßschraube - Oil-drain screw - Bouchon à vis de vidange d’huile - Tappo scarico olio 1
- 900.123.011.30 Dichtring für Ölablaßschraube - Gasket ring for oil-drain screw - Anneau-joint pour bouchon à vis de vidange d’huile - Guarnizione di tenuta per tappo scarico olio A 22x27 DIN 7603-Al 1
- 901.101.391.00 Dichtung für Ölsieb - Gasket for oil strainer - Joint pour tamnis d’huile - Guamizione per filtro olio 2
- 901.609.301.12 Zündkerzenstecker - Spark plug connector - Fiche pour bougie d’ allumage - Spina candele 2
- 999.659.016.50 Gummikappe für Zündkerzenstecker - Rubber cap for spark plug connector - Capuchon en caoutchouc pour fiche pour bougie d’ allumage - Coperchio di gomma per spina candele 2
- 901.108.945.00 Dichtungssatz für Vergaser - Set of gaskets for carburetor - Jeu de joints pour le carburateur - Serie guarnizioni per carburatore 1
- 901.423.401.01 Kupplungsseil - Clutch cable - Câble de débrayage - Cavo Frizione 1
- 901.104.191.00 Zylinderfußdichtung - Gasket for cylinder base - Joint pour base du cylindre - Guarnizione basamento cilindro 3
- 901.104.391.00 Zylinderkopfdlchtung - Gasket for cylinder head - Joint de la culasse - Guarnizione testa cilindri 3
- 901.105.193.02 Dichtung zum Kurbel - und Kettengehäuse - Gasket for crank- case and chain housing - Joint pour carter de moteur et de chaînes - Guarnizione sulla scatola di trasmissione 1
- 901.105.192.02 Dichtung für Kettengehäuse rechts - Gasket for chain housing right - Joint pour carter de chaînes droit - Guamizione per scatola trasmissione destra 1
- 901.105.191.02 Dichtung für Kettengehäuse links - Gasket for chain housing left - Joint pour carter de chaînes gauche - Guarnizione per scatola trasmissione sinistra 1
- 901.105.194.03 Dichtung für Deckel, oben - Gasket for upper cover - Joint pour couvercle supérieur - Guarnizione per coperchio superiore 2
- 901.105.195.03 Dichtung für Deckel, unten - Gasket for lower cover - Joint pour couvercle inférieur - Guarnizione per coperchio inferiore 2
- 901.105.197.00 Dichtung - Gasket - Joint – Guarnizione 1
- 999.701.124.40 O-Ring - O-ring - Joint annulaire - Anello di tenuta 1
- 901.105.592.01 Axia-Gleitringdichtwig - Slide sealing ring Axia - Bague glissent d’étanchéité Axia - Guamizione Axia 1
Jim Alton
Torrance, CA
Early 911S Registry # 237
1965 Porsche 911 coupe
1958 Porsche 356A cabriolet
I have an original NOS one for a 1971 914-6. I wonder if its the same?
Pics to share????
Here are some good reference pics of a NOS kit similar to what SM have tried to replicate (FB link)
http://www.early911sregistry.org/for...it-for-MFI-911
S-Reg #1382
67S Lavender
