Results 1 to 9 of 9
Thread: Value of 2.2S pistons?
    Feb 2012
    Mississauga, On
    Can anybody tell me what a set of 2.2 911S pistons and wrist pins are worth? Original with slight corrosion...
    Rob
    Banned
    Nov 2004
    Scottsdale, AZ
    Sounds like a sweet set of high compression paper weights.
    You lost me with the "slight corrosion" line but pics might help. Or not.
    Good luck with the sale.
    Jan 2006
    Naperville, IL
    Rob,
    That is a hard question to answer without completely understanding the condition of your pistons. Flipping through a few completed ebay sales it seems an in-spec set should be easily worth a few hundred dollars +/- a hundred.
    Example is for an for an E and includes jugs and a new ring set so take that into account:
    http://www.ebay.com/itm/Porsche-911-...4d1043&vxp=mtr
    The ad also has some specs quoted; as Frank noted photos could help assess the "slight corrosion". This could be enough to create a hot-spot(s) and cause premature detonation. Not a good thing, especilly for those of us that would like a set of 2.2S pistons for a compression bump from say 8.0:1
    Hope this helps,
    -Andrew
    '72 911E
    '82 931, '92 968, '93 968
    S Reg #1074
    Feb 2012
    Mississauga, On
    Thanks Andrew, I appreciate the explanation.
    I responded to a guy on the bird looking for a set and I said I had them but I have no idea what they are worth - I'm really just looking to arrive at a fair market price.
    Attached are a couple of pics. I look forward to any input, thanks.
    Feb 2012
    Mississauga, On
    Maybe these are better pics...
Size:  94.8 KBName:  IMG_0034[1].jpg
Size:  50.4 KBName:  IMG_0036[1].jpg
Size:  72.1 KBName:  IMG_0035[1].jpg
Size:  82.3 KBName:  IMG_0037[1].jpg
    Feb 2012
    Mississauga, On
    One more...
    Jan 2006
    Naperville, IL
    The detailed pictures help; If the skirts and ring lands measure to all be in spec you may be able to get $200 for the set. Personally, the corrosion as seen on photo #1,#3 and #6 would keep me from using those.
    -Andrew
    '72 911E
    S Reg #1074
    Feb 2012
    Mississauga, On
    Thanks for input although $200 probably isn't worth my while.
    May 2009
    West LA
    I bought a full set of 2.2S P&Cs last year for $1800 on Pelican that were in VG condition. I later saw a set for $2K. I haven't seen another since. I have no idea what pistons alone are worth.
    Registry Member #1583
