Thread: Restoratin of tail, and signal light`s
    Nov 2010
    Norway
    Before I start to restore my light housing I want to have advices from you how to do it.
    Is blasting with glass or soda the best.
    How to paint the reflector?
    If its a tread please let me know.
    best
    Stig-T
    The Netherlands
    Ha det Stig,
    Just be careful with blasting, the alu housing is pretty soft and most likely oxidized around the bolt holes. It gets thin very easy. You can try paint thinner on the inside and use of plastic scraper to get the paint of. Then a layer of white paint and leave it like that or try silver/alu whatever paint but you will never get a shiny finish as per factory. There are profi's that can spray/damp silver but it is very expensive.
    Cees
    Jul 2014
    Long Island NY
    Rustoleum makes a "chrome" spray, did some tests and looks pretty good, don't know if it will hold up long term.? Rustoleum paint in general is pretty good stuff, have used various colors on other cars
    Pay to play Schiefer's Avatar
    Jun 2008
    Norway
    Quote Originally Posted by RSexS View Post
    Ha det Stig
    Hi Cees,
    Your Norwegian vocabulary is quite impressive, but you made a little mistake here.. "Ha det" means goodbye. You could write "hei der" (hello there). If you want to get into the advanced stuff I can send you a list with popular phrases like "hallo gamle ørn" (Hello old eagle) if you want to greet and impress an old buddy like me!
    S-Reg #1382
    67S Lavender
    Aug 2011
    New York
    I lightly bead blasted first. I filled any problem areas with JB Weld. Then I sprayed the interior with Rustoleum primer, white, and then Chrome paint.
    It is holding up well after 4 years now.
    E Sully
    1973.5 911T
    Jul 2014
    Long Island NY
    What the "other" Sully said, that is the exact route I will take when I do mine.
