I need the vertical dimension of the rear window for a 1967 coupe. I have a shop manual however unclear if the opening is 27 5/16 inch or 693.5 mm
I measured one coupe rear window at center line at 27 7/16. Any clarity would be greatly appreciated.
Does anyone know of a template fixture for the rear window? The windshield has a steel fixture for body repair. I'm looking for the rear window.
Gene
