Results 1 to 8 of 8
Thread: Porsche 911 2,2 S engine wire
    Dear Porsche 911 owners, I have a wire to reconnect in the engine bay to the engine.
    I am a bit lost as some of the wire have been cut.
    If someone could help me, may be ??
    I would like to know on the large black plug with some numbers written were and which color wire to place on the plug !!?
    Here are some pictures, thanks for the help
    http://www.hostingpics.net/viewer.ph...55P1000885.jpg
    http://www.hostingpics.net/viewer.ph...50P1000886.jpg
    http://www.hostingpics.net/viewer.ph...71P1000887.jpg
    http://www.hostingpics.net/viewer.ph...89P1000888.jpg
    Feb 2012
    Kolham, Groningen, The Netherlands.
    Engine harness connector
    Hope this helps (do you need the pin out of the engine harness connector?)
    This is coming from our connection diagrams, if you need more info just let us know.
    Best regards from the Netherlands,
    Gerard Kroon
    Kroon Wire Harnesses.
    aansluitschema 911 1972 LHD 2013-12-07.xlsx.pdf
    Its coming from the front of the car, many thanks
    Chris
    Is this correct for a US 2.2S also? ,I noticed it said 1972
    Its for a 70 so I hope it's working to !!?
    Great to hear it is working! Cheers.
    Feb 2012
    1970 Front to aft harness female connector
    This is the pin out for a female connector from the 1970 "front to aft" harness.
    aansluitschema 911 1970 LHD 2013-10-30.xlsx.pdf
    Many thanks, I should be OK with those, let you know
