I see several references to 'longblock' in engine related threads. What does this mean, an somebody enlighten me?
member 2971 Jacques
911 March 1965
912 April 1965
911 May 1965
964 RS clone (one of many)
964 Targa original Dutch police car (one of 45)
964 Turbo 3.6 (one of 1450)
993 S Vesuvio (one of 250)
pss,
I'll try, at least this is it what it used to mean a long time ago:
- A 'longblock' meant the engine is complete from valve cover to valve cover and from flywheel to crank pulley.
- A 'complete' engine usually meant all of the above plus all the induction and exhaust systems, clutch assembly, and starter.
- A 'shortblock' usually meant just the engine block (the case) with crank, rods, and pistons installed....
I'm sure others in the business with chime in.... however, that's what I'd expect... for about the last 45 years.....
Hope this helps
oufff, thanks Chuck. For a moment I thought I had missed a complete chapter in Porsche engine development............
member 2971 Jacques
911 March 1965
912 April 1965
911 May 1965
In my opinion, a longblock includes a distributor minus intake/exhaust as stated above, plus or minus the flywheel. It's a very good question and frequently used term without a clear definition.
MBR #2637
AKA boschdog
1968 911 Normal Coupe
Houston, Texas
Yep DT, I agree. A longblock (and of coarse a 'complete') should include a the distributor.......... I forgot the sparkenzee.......
More info...
http://en.m.wikipedia.org/wiki/Long_block
Peter Kane
'72 911S Targa
I would not expect a long block to include a distributor but some do. and would not expect an air cooled short block to include pistons and cylinders like a water pumper does. The terminology is cloudy.
