Thread: installing retractable belts
    Jun 2011
    Bellingham, WA
    My 72 911 came with standard 3 point belts. They mount at top of B pillar and left & right on the seats. I have just purchased retractable belts. I cannot find the threaded mounting hole for retractable leg. Is it at the bottom of the B pillar or do I use the hole for the rear sat belts. Or is there another threaded hole?
    There is another threaded hole, remove the rear inner panel.
    Feb 2012
    Edmonton
    I stole this pic from Google, you can see the bolt hole just below/behind the stamped triangle section
    The Netherlands
    seat belt mounting
    From the manual:
