Thread: Activate the horn with Hockey puck/Batwing
    Oct 2010
    Denmark
    I would like to have a hockey puck on my 380mm double wrap, but how does it activate the horn? as it can not be pressed down as my current batwingP
    thanks
    Lars
    1967 911 Bahama Yellow
    1962 356 TB 6 Slate Grey
    1982 911 SC gone
    1965 911 gone
    1968 911L gone
    Bump.....I'd also like to know.
    JEFF BRINTON
    ESR #1572
    1968 911N
    1974 914 2.0L
    2023 Macan
    SOLD - 1967 911N / 1968 911L / 1967 911N / 1969 912 / 1991 964 C2 / 2013 991.1 / 2008 987 Cayman
    Jul 2003
    Santa Cruz, CA
    Ummm, it should work as both have the very same mechanical mechanism to the best of my knowledge. You should have the same horn contact ring, horn contact button and the rubber isolator. I would pull the hockey puck to see what the problem is.
    Michael
    -Dusty 70S Coupe
    -S Registry #586
    I had that issue too on my 68 912... My hockey puck was missing a spring and horn contact (SMC has a cheap kit for repairing this, cup, spring, contact). Without that stuff it felt glued to the hub, like you could not press it down. But once I added both missing bits (esp the spring), it does work by just pushing on it - I can now hear the horn relay click. Just gotta finish troubleshooting between that relay and the horn(s?) now and I'll have it fixed ! Pull it and look (quarter turn left if I recall)
    Greg.
    72 911T - 73 2002
    #1461
