Results 1 to 8 of 8
Thread: engine -transmission question
    Senior Member tonizzos's Avatar
    Mar 2012
    Luxembourg
    hi i just got a 1968 T engine to match my 68 SWB restauration..... but i have a 915 trans
    so my question , can i match the 68T engine with the 915 trans?
    thanks for help
    cheers
    steve
    if you use the correct flywheel + clutch package you can. Any reason you want to use a 915?
    Richard
    Mar 2012
    Luxembourg
    yes, because i have a 915 trans and not a 901 hahahha
    i bought a restauration project and i got the 915 trans with it... i was lucky to find a 68 engine that is less than 500 numbers away from my original one ... so i was wondering if i could put both together
    but thanks for your answer .... i found a lot of 901 trans with bigger engine conversions but none in the other sense
    if you post a picture of your flywheel we can tell if you have a 901 or 915 flywheel. Most likely it's a 901 flywheel but may be you are lucky and the PO used a 915 too .. An easy tell between a 901 and 915 flywheel is whether the starter ring is fixed or bolted.
    You could also consider to swap your 915 for a 901 + money. I would do such a swap w/ you if you were close.
    Richard
    Mar 2012
    Luxembourg
    Quote Originally Posted by preS View Post
    Richard
    thanks richard
    i will get my engine tomorrow , will post a picture of the flywheel
    steve
    Hi Steve,
    what kind of 915 trans ? mag or alu? mecanical or electronic speedo ?
    Mar 2012
    Luxembourg
    It's written 915/60 on it
    Quote Originally Posted by tonizzos View Post
    That most likely is a Mag 915 w/ elec speedo.
    Is your speedo electronic? If mechanical make sure you will need a tranny for mech speedo or get a later speedo.
    Richard
