Results 1 to 10 of 11
Thread: ignition switch diameter
    Senior Member pss's Avatar
    May 2014
    Netherlands
    I have 2 different ignition switches: one US and one EU version with steering lock.
    Although the outer form of the bezel is exactly the same, the inner thread is quite different. The US version diameter is ~0.7 inch (~2 cm) and the EU version shows ~1 inch (~2.5 cm).
    I was wondering whether both are correct for my 1965 US and EU cars.
    member 2971 Jacques
    911 March 1965
    912 April 1965
    911 May 1965
    964 RS clone (one of many)
    964 Targa original Dutch police car (one of 45)
    964 Turbo 3.6 (one of 1450)
    993 S Vesuvio (one of 250)
    One uses bullet connectors and the other uses spade connectors. The correct one is the one that matches the wiring in the car.
    Senior Member moito's Avatar
    May 2013
    AUSTRIA (tu felix)
    i have never seen a euro car without lock.(does not mean they dont exist)
    Senior Member haul's Avatar
    Jul 2014
    bavaria
    i have never seen an us car with lock (does not mean they dont exist)...gruss an f
    May 2014
    Netherlands
    Well I know which one belongs to which car, it is just that I wonder whether they are both period correct as the generic part differs so much. I don't know why they would change the thread as only the back-end's functionality is different.
    Are they both period correct you guess?
    member 2971 Jacques
    911 March 1965
    912 April 1965
    911 May 1965
    Jul 2014
    bavaria
    yip, both correct...do you have the 911 spare part list?there you can look at it either....
    http://www.porsche.com/germany/acces...artscatalogue/
    select the 911/912 65 to 67 catalogue and enjoy the literature
    Aug 2009
    SF Bay Area
    Quote Originally Posted by haul View Post
    All non locking ign switches are thinner than locking ign switches.
    Jim
    May 2014
    Netherlands
    Txs all, very useful!
    Great link, will avoid me asking too many these questions
    member 2971 Jacques
    911 March 1965
    912 April 1965
    911 May 1965
    Nov 2010
    North Carolina
    One reason the locking switch has a larger diameter is because it has two sets of pin tumblers at 90 degree angles, so that the key can be removed without engaging the lock. The US switch is largely a holdover from the 356, and I assume used in US cars as it was not required by regulations and was cheaper. But as everyone knows, the hole in the dash was designed for the locking switch. In fact the locking switch can be installed on a US car, you just have to get the parts and line up the holes in the steering column.
    SV
    May 2005
    Oroville, CA
    When we ordered a new switch for an early car (<69), the first thing asked was if it was locking or not. I never found a true pattern. Maybe because so many early ROW cars were imported in our area?
    Anyway later, they all seemed to get the locking versions. I tend to agree with Ed.... Put in the one that fits.
    I personally think it was a bad design because they lock up when the steering is pinched and customers would break off the keys trying to turn the ignition without releasing the steering wheel pressure. I even heard of a person trying to coast and the lock engaged, then they panicked and crashed...and it doesn't deter a thief as designed.....
    Now back down off of the soap box.
    H
