Thread: Oil Temperature/Pressure Gauge p/n
    Junior Member
    Jan 2010
    Ann Arbor
    What is the p/n for the oil/pressure and temperature gauge to replace the temperature-only gauge on a '73T? 911 641 103 00?
    Are there corresponding sending units used with the gauge?
    route11,
    The part number you listed, 911.641.103.00 is the "combined instrument" (that's what the parts book calls it) it's the German version, (instrument face) used in the 911S, and Carrera 2.7, this part is also listed as optional for the 911T carb. and 911E.
    The part number 911.641.104.00 is the same as above but the English version, (instrument face). Both are oil pressure and temperature. this info is from the 72/73 factory parts book.
    Ernie W
    member of Early 911S Registry
    Junior Member
    Jan 2010
    Ann Arbor
    Ernie
    Many thanks for the clarification. Is there any indication in parts book that same or different sending units used?
    Tom
    Tom,
    The oil temperature sender is the same part number, 901.641.632.00 for ALL.
    The transmitter for the oil pressure gauge is 901.741.551.01 This is for the 911S, Carrera 2.7, and Sportomatic. This one is for the gauge (combined instrument) listed above in post #2.
    The 911T Carb., 911T, 911E show a part number of 911.613.571.00 for the pressure transmitter. and for the 911T CIS, 911.613.571.01
    all info is from the 72/73 factory parts books.
    Ernie W
