Results 1 to 8 of 8
Thread: 72 oil line question
    Senior Member michaelaiellosr's Avatar
    Apr 2014
    New York/Florida
    I bought this restoration project in boxes so I don't have the advantage of having taken the car apart. It came with factory 72 hard and soft lines to a front cooler (try to find those parts!!).I believe this part is the return tube from the 72 oil reservoir to the engine cooler. All the documentation I can collect does not reveal what is connected to the small welded boss fitting off the tube (looks like a -6 male connector). It's probably something like a vent line from the engine , but if anyone has definitive info it would be greatly appreciated as always. Thanks, MikeName:  72 911 oil return tube.jpg
    It is for a sportomatic transmission line connection. Engine oil was used in the shifting mechanism (I think), not for the gears which used conventional gear oil.
    Gib Bosworth
    EarlySReg 434
    R Gruppe 17
    Apr 2014
    New York/Florida
    hmmm...guess that needs to be blocked off, or cut off and plugged/patched. Thanks Gib
    Senior Member SpawnyWhippet's Avatar
    Mar 2013
    San Francisco Bay Area
    My manual transmission 1972 doesn't have that adapter piece, I just repainted it.
    Member # 2899
    1972 911T
    2004 996 C4S
    2001 996 Carrera
    2008 Cayenne S (sold)
    2004 Cayenne Turbo (sold)
    2009 997 cabriolet (sold)
    2002 996 Turbo (sold)
    1998 Boxster S (sold)
    1997 993 cab (sold)
    1989 911 3.2 Carrera (sold)
    Apr 2014
    New York/Florida
    Do either of you have a front cooler on your car and do you have installed the factory parts for the front cooler?
    You can order the hard lines and most of the components from Porsche these days. Check the PET...scroll down to the oil tank and lines page and get P/Ns. Call Sunset Porsche in Portand, OR for help and good prices.
    http://www.porsche.com/all/media/pdf...73_KATALOG.pdf
    Gib Bosworth
    EarlySReg 434
    R Gruppe 17
    Mar 2013
    I don't have the front cooler
    Member # 2899
    1972 911T
    2004 996 C4S
    2001 996 Carrera
    1997 993 cab (sold)
    Elephant racing has the '72 w/oil cooler line issue sorted out!
