Thread: 1972 911T CV Bolt Clamp
    I have a (new to me) 1972 911T. While the car was on a lift yesterday I noticed that the driver side CV boot had clamps on both sides (inner and outer) of the boot. The passenger side CV boot, looking much newer than the other one, did not have any clamps. Are there supposed to be clamps on these boots and, if so, can you plz advise as to the correct part number (s). I have looked at the 1972 PET and it's not clear to me if there are supposed to be clamps on both sides (inner and outer) of the CV boots.
    Harry
    Early 911s Registry Member # 3046
    1970 911T w/3.2L
    R Gruppe # 780
    2003 Boxster S
    2007 997.1 GT3
    2018 Macan S
    Jan 2011
    DFW TX
    The large side should have a clamp, the small side clamp is optional. I usually use a tie wrap on the small side. There are four CV joints, check the other two too. I recommend you use the factory clamps PN 999 512 486 00. I recently tried some clamps from Pelican and although they were 74mm Oetiker brand clamps they did not have the proper coarse adjustment to fit correctly.
    Thanx, Mike. Appreciate your input.
    Harry
    1970 911T w/3.2L
    R Gruppe # 780
    2003 Boxster S
    2007 997.1 GT3
    2018 Macan S
    Senior Member 911kiwi's Avatar
    Feb 2003
    Auckland, New Zealand. And Los Angeles, USA.
    Resurrecting this thread. Anyone recently bought clamps for their CV boots? And what was the verdict. I've tried the 911.332.257.00 and then 999.512.486.00 from SMC. Neither enabled me to clamp the boot securely - both too large. Are the ones from Porsche different? Or are the likes of SMC and Pelican packaging the same parts with different part numbers? Appreciate advice as the local auto store clamps don't look as good as the OEM ones.
    Kiwi
    1972 911S
    1967 912
    1959 356A Conv D
    Early S Registry # 306
    Jan 2011
    DFW TX
    Apparently I'm repeating myself. Time flies.
