Thread: 15mm Front Factory Sway Bar Kit Complete
    Jul 2006
    Corvallis, OR
    Here's a factory 15mm front sway bar kit. The 15mm bar has been powder coated. Everything else in the kit is brand spanking new. The only thing missing are the 2 15mm bushings which you can get from Porsche. What's extra special about this kit are the arms that attach to the sway bar. These are very late arms that have extra strengthening around them where the bar slides through the arm. I've NEVER seen this on a 15mm arm only the 18mm 76 turbo arms came stock this way. So, this is a good improvement because this is where the early stock arms are weaker and can wear. Especially if the bolts come loose the arms would wear at this location. I'm showing 4 arms in the picture only so you can see what I'm talking about. If you didn't want the improved arms for some reason I could include the more common early 15mm arms. It will only come with 2 arms not 4. $725.00 shipped in US. Thanks, -Scott
    72S, 72T now ST
    Scott,
    I'll take these.
    Phil
    Early S Junkie # 658
    Atlanta, GA
    Scott, very nice and so organized. Where do you get the bags from? I like!
    Mark Erbesfield
    1973 911S #9113301282
    1957 356A #58648
    1982 Toyota Land Cruiser FJ40
    1977 Toyota Land Cruiser FJ40
    1979 MB 450SL "Dad's old car"
    2019 Cayenne "Wife's car"
