Thread: Massaged rods....
    Massaged rods....
    I have five rods that look to be 66mm crank rods but they are different from stock 2.2 rods. Here are pics of the rods. And then a comparison to a 2.2 rod. Finally the five rods side by side with a detailed "stamping" to identify which P and C they refer. It was suggested that these are early rods from a race engine? They are definitely of an alloy that seems to be steel. Your help is appreciated.
    Speedo
    registry# 1283
    They are just early 2.0 liter rods that someone has lightened by grinding off a lot of metal, then because he had ground off all the matching cap/rod numbers he center punched them so the rods and caps wouldn't get mixed up.
    What is the weight? with and without bolts?
    Ok...
    2.0 rods with bolts 645 grams w/o 563 grams
    As compared with some 2.2 rods which are 745 grams with bolts and w/o 712 grams.
    How much did the original 2.0 rods weigh? I'm curious....
    Speedo
    registry# 1283
    Senior Member 2.5MFI's Avatar
    Sep 2006
    Bend, Oregon
    Early 2.0 rods with bolts: 649.0 to 651.50 grams for the set I have.
    Mark Jung
    MFI Werks
    Early 911S Registry #972
    Carrera T w/LWB, MT, RWS, PCCB
    72 T 66 x 100 MFI Twin Plug Coupe
    R Gruppe #686
    That surprises me...I would have thought the stock weight would have been higher. Lot of work to go through to save 5 grams. Yours are stock, right Mark?
    registry# 1283
