Results 1 to 9 of 9
Thread: What is this on the KYB shock?
    Oct 2010
    Denmark
    Hi , I just took this old kyb shocks of my plain 911 swb 66/67 , can you se if they can be the original ones?,perhaps never been out of the car before?
    what is that strange leather "thing on the shock,? it was sitting there when the shocks came of.
    thanks
    Lars
    1967 911 Bahama Yellow
    1962 356 TB 6 Slate Grey
    1982 911 SC gone
    1965 911 gone
    1968 911L gone
    Feb 2003
    Corpus Christi, Texas
    KYB is junk so definitely not OE on Porsche. My guess is that strap was used to keep the shock compressed during shipping and the installer left it in place while installing and then cut the string to let the gas pressure extend the shock.
    Jason Burkett
    Paragon Products
    www.paragon-products.com
    Early 911S Registry #428
    R Gruppe #375
    1973 911S
    1972 911T
    1974 914 Limited Ed. Blk/Yellow
    1989 944 Turbo
    1993 968 Turbo RS
    1967 Shelby GT500
    1968 Shelby GT500 Conv.
    2010 VW GTI, Daily Driver
    Oct 2010
    Denmark
    thanks jason, I`m installing red koni Classic now so hope to fell a difference to the good side :-)
    1982 911 SC gone
    1965 911 gone
    1968 911L gone
    Feb 2003
    Quote Originally Posted by lars1965 View Post
    Your car will thank you!
    Jason Burkett
    Paragon Products
    R Gruppe #375
    1973 911S
    1972 911T
    1989 944 Turbo
    1993 968 Turbo RS
    1967 Shelby GT500
    Oct 2010
    Denmark
    jason, do you know how much to tighten down the nut on the towers in the engine room?
    I have 1 rubber+ metal tube mounted on the top of the shock upwards in the tower room to the engine room , and in the engine room 1 rubber + 1 big washer + nut.
    1 have about 10mm visible thread now after i have tighten the nut?
    thanks
    Lars
    1982 911 SC gone
    1965 911 gone
    1968 911L gone
    Jan 2007
    North of the GG Bridge
    Is this what you need? This info came with my Koni's.
    Feb 2003
    thanks
    Lars
    Lars, I should have taken a peek at a set when I was at work yesterday to see if Koni gives a torque spec. I'll check on Monday. Ed Mayo may chime in here but I've just always used my "calibrated arm" to snug these things up and get some squish to the rubber bushings on top.
    Jason Burkett
    Paragon Products
    R Gruppe #375
    1973 911S
    1972 911T
    1989 944 Turbo
    1993 968 Turbo RS
    1967 Shelby GT500
    Oct 2010
    South Carolina
    Big nut on top of lower half of strut = 90 ft lbs
    Nut on top of strut tower to chrome part of strut = 60 ft lbs - most of us just use an impact gun and TLAR it. If you can find a spanner to hold the notched washer then you can torque it. I've seen folks use a channel lock on the washer - oh the horror.
    I'm with Jason,,,,,I hold the shock top with with the appropriate wrench, then turn the nut with a ratcheting box end wrench. There is a spacer tube on the shaft so you really can't over compress the rubber. It will feel tight enough before you get to that point.
