Thread: Switch Bulbs
    Switch Bulbs
    None of my car's switches (lights, rear window defogger, driving lights) light up, so am i correct to assume their bulbs are burned out? If yes, what size bulbs do these switches take, and is there any particular "trick" to removing and replacing them?
    Cheers!
    Frank Kohnen
    Jupiter, FL USA
    Registry Member #921
    1972 Bahia Red 911 Coupe #9112100390..."Rudy" SOLD
    1967 Savannah Beige VW Beetle Sedan #117364457..."Heidi"...aka "Tinker Toy"
    #2264 classic's Avatar
    Nov 2004
    Gold Coast.
    Frank for all of them to be out, I'd be pulling out the multi meter.
    Their daisy chained together, but one won't take out the next one.
    Check if the PO fitted an inline fuse (common upgrade) as the dash lights are normally un fused.
    Your earth can be found behind your clock, in the front.
    And incase non of that works......
    http://www.sierramadrecollection.com...-89-p2538.html
    Tony
    Quote Originally Posted by classic View Post
    Thanks Tony
    Cheers!
    Frank Kohnen
    Jupiter, FL USA
