Results 1 to 7 of 7
Thread: Remove quarterlight glass?
    Dec 2013
    Camas, WA
    Whats the best procedure for removing the quarterlight (wind wing) glass from a SWB frame, without damaging anything?
    I've searched this forum but can't seem to locate anything.
    Thanks for any suggestions
    Aug 2009
    SF Bay Area
    Remove the frame from the door and then remove the vent assy from the frame. I've done it about 500 times. You can do 90% of the job with a 5mm Allen , a 7mm open end wrench, a 10mm socket and a 10mm open end wrench.
    Jim
    Dec 2013
    Camas, WA
    I'm talking about getting the glass out of the frame so I can have the frame re-chromed.
    Watched my body man dale do it recently. Used a "special" tool. Namely a butter knife which he kept inserting between seal and glass. Had to "worry" the glass out by pushing and pulling incrementally. Very slow process.
    Aug 2009
    SF Bay Area
    I use a small screw driver and just pry the glass out of the frame. I've done it too any times to count. I wouldn't recommend it to everybody, though.
    Jim
    Nov 2006
    S. F. Bay Area
    And use some heat! If you have a heat gun get it good and warm.
    Brian
    S Reg #1032
    Nov 2002
    San Dimas, CA
    It's been a long, long time since I disassembled my vent windows, but I think I used hot water to soften things then more or less pulled the glass out.
    Jim Alton
    Torrance, CA
    Early 911S Registry # 237
    1965 Porsche 911 coupe
    1958 Porsche 356A cabriolet
