Thread: What is the correct rear quarter trim for an early 911?
    First of all: best wishes!!
    I am slightly confused: I am finishing the rebuild of my 911 and I just discovered that 1 of my trims has holes in them for stews and the other does not have these holes. Just wondering what original is for an early 911?
    My 1970 911 has the trim with the screwholes. Just wondering whether the early SWB cars had screwless trims? If so, how were these trims attached?
    Frank
    Senior Member moito's Avatar
    May 2013
    AUSTRIA (tu felix)
    if you are talking about the inside trim : first seen on the 67S (this has of course the j-mold attached to it ) while normal `67 did not have the trim that goes around the b-billar.
    May 2005
    Oroville, CA
    The brass quarter trim on the SWBs have studs tacked to the trim.
    The LWB aluminum has the holes for the screws to go through.
    Sorry, I don't have a 68 here to check since they are a change over year.
    H
    Ok, cool! Learned something again today! Thanks a lot for the help.
    Much appreciated.
    Aug 2009
    SF Bay Area
    The aluminum trim started with the 68 YM cars
    Jul 2008
    Holland
    Quote Originally Posted by Harvey Weidman View Post
    H
    Harvey,
    How are the studs secured from behind?
    Slate Gray, Red Leather, 1968 912 HWT
