Results 1 to 2 of 2
Thread: SWB master cylinder rod
    May 2006
    Riverside CA 92505
    I have a customer needing a SWB master cylinder. These are the longer 118 mm rod used 1965-1967. The later pedal sets used a shorter 90 mm rod. I really only need the rod but if you have the base that it screws into I will take that too.
    Aug 2009
    SF Bay Area
    I,ve got one.
