Thread: Early door card material, where can I find it
    Anyone have a source for the early door card material? What is it made of and what is the silver finish on the inside face, paint? Looking for something suitable for a 67. Is there a proven method to flatten warped cards? I know lots of questions, any help would be appreciated.
    Skip
    #2264 classic's Avatar
    Nov 2004
    Gold Coast.
    Skip,
    I used Coreflute for my door panels, it's the stuff they make real estate signs out of.
    It's light and completely water proof, takes glue and staples well.
    You may have to order the 3mm staples from an online store, or purchase some from an upholstry store.
    The next best thing is marine grade Masonite, it's water resistant, but now water proof.
    Hope that helps.
    Tony
    try app biz, they sell a very nice material, pre cut and pre stamped for any configuration.
    Dec 2003
    West Los Angeles
    That sounds like the material used for the cardboard fuse cover. In LWB cars, a cardboard like material was used, but instead of a silver facing, the inner door shell was covered in a plastic membrane sheet, which I imagine does a better job of waterproofing. I have and have used the Appbiz parts and I have also cut my own out of Lexan, which obviates the need for the membrane.
    techweenie.com
    Jul 2003
    Santa Cruz, CA
    Quote Originally Posted by Eminence Gris View Post
    The SWB door card and the fuse cover was indeed the same material.
    Here are some links to peruse:
    http://www.perfectfit.com/15347/1545...anelboard.html
    http://www.yourautotrim.com/
    http://www.garysupholstery.com/products.html
    http://www.smsautofabrics.com/
    http://www.worlduph.com/porsche/
    Michael
    -Dusty 70S Coupe
    -S Registry #586
    Thank you gentlemen for your responses.
