Results 1 to 2 of 2
Thread: Strange pair of center lube cams
    Took these out of a good running 2.0 engine a few years ago. I think they were a matching pair originally.
    Left cam 90110510901. Appears to be original early center lube cam.
    Right cam, 9011051101R, had the end cut off for some reason and drilled to have the bolt installed in the end like a 82 or newer 911SC. At worst,there is a good left center lube cam. In any case, I would recommend have the cam/cams re ground to your spec before use. $275 for the pair+ shipping
    Sold, thanks everyone who replied.
