Results 1 to 10 of 15
Thread: VIN lookup from Engine Number?
    So... I have a little bit of a different request than normal...
    I'm trying to trace my grandfathers 1976 Blue 911 2.7 Coupe.
    All I have to go on is a picture and a UK registration plate. (PAY 120R)
    Using the UK lookup up service I've found out the car last changed owners in 2007.
    The same check provided the engine number (Engine No. 6362727) but no VIN
    Any idea how I could use the engine number to trace the VIN?
    Best Regards,
    Michael
    Member No. 2861
    @p911r on Instagram
    Jan 2003
    UK
    All you can ascertain from the engine no. 6362727 is that it was a 'base' model (165bhp) '76 911.
    If you know it was a Coupe then the VIN will be in the range 911 630 0001 - 911 630 1868
    There were 3029 of those engines installed in '76 & although engine numbers weren't always fitted 'in sequence' with the chassis numbers (VIN's) & the same engine type was fitted to '76 911 'base' Targa models, you can reasonably say that the VIN that received that engine was near to the end of the range mentioned above.
    Andy
    Early 911S Reg #753
    R Gruppe #105
    Thanks for the info it's much appreciated 👍
    Member No. 2861
    @p911r on Instagram
    Senior Member SpawnyWhippet's Avatar
    Mar 2013
    San Francisco Bay Area
    I've been offered a rebuilt 1972 911T engine with the serial 6122563. I would like to locate the original chassis and see if the owner wants to reunite them. Any way of doing this?
    Member # 2899
    1972 911T
    2004 996 C4S
    2001 996 Carrera
    2008 Cayenne S (sold)
    2004 Cayenne Turbo (sold)
    2009 997 cabriolet (sold)
    2002 996 Turbo (sold)
    1998 Boxster S (sold)
    1997 993 cab (sold)
    1989 911 3.2 Carrera (sold)
    Peter Kane
    '72 911S Targa
    This is the car I'm trying to trace... It was my Grandfathers.
    Member No. 2861
    @p911r on Instagram
    Jan 2003
    UK
    According to the DVLA website, the car is here in the UK but is currently 'off the road' (its status is declared as 'SORN' - statutory off road notification) which typically means it's either undergoing restoration or other work.
    Its last MOT certificate (compulsory annual test) expired on 24th August 2013.
    Andy
    Early 911S Reg #753
    R Gruppe #105
    Great info Andy,
    It's exciting to know it still exists.
    Now for the tricky bit... Finding and contacting the owner.
    Member No. 2861
    @p911r on Instagram
    The 1976 Blue 911 was not his only Porsche...
    He had a 911T in the early 70's... unfortunately the reg (JRS 911F) is no longer with the car so I have no way of tracing it (unless anyone know of a way?)
    Grandpa's 911T by @p911r on Instagram, on Flickr
    Member No. 2861
    @p911r on Instagram
    Dec 2003
    West Los Angeles
    Quote Originally Posted by Michael Meldrum View Post
    Best Regards,
    Michael
    I have a connection to find the chassis number from engine number. Not cheap. If you're interested, PM me.
    techweenie.com
