Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: Parting a 1969 2.0 E engine
    Senior Member greggearhead's Avatar
    Colorado Springs, CO
    PRICE DROPS
    Engine threw a rod. I have the case halves, one has hole, other side has a pretty good scrape. Not sure if they are worth anything, but if someone wants them, make me an offer.
    SOLD 5 pistons and cyl in OK shape $100 SOLD
    5 Connecting Rods - look good but should be sized. $75
    SOLD Carrera tensioners "kit" with idlers, chain box covers and oil lines $350 SOLD
    Chain Boxes $50 pair
    Behr Oil cooler - has been washed but will need flushed. $100
    SOLD Flywheel - needs surfaced from sitting $100 SOLD
    Scrapped - TOO BENT - Crankshaft - has damage on journal that obviously got hot, having checked for straightness. $150
    SOLD Cylinder cooling tins $25 SOLD
    More soon - heads, cams etc.
    Dec 2008
    Black Mountain, NC
    Is that not a T crank (non counter weighted) listed under an E motor parting out??
    All E came with a counter weighted crank, that crank may have been in the case but if as it appears, is not correct.
    not trying to start anything, just think it needed clarification. Free bump for other stuff
    Tanks Jerry - no offense taken, I welcome anyone's knowledge that helps to better identify parts. The motor had headers, and I'm not sure about the cams yet, so it may have been rebuilt into something different.
    As an FYI - here is the case number and serial:
    PMs replied to.
    Distributor - Boch # 0 231 159 006 $225
    First person in line for cams has been PM'ed. In case he passes - They are 'T' cams, with one lobe having some very minor damage/wear.
