Thread: Halon fire bottle removal - question please
Size:  98.7 KBFull disclosure - this is not from my 73S, but such projects help pay for it . I am hoping someone on the Forum can tell me how to safety disconnect the system...the line that enters the top of the bottle goes to the PUSH FOR FIRE red button inside the car. Where the line enters to the top of the bottle (after the bracket and two nuts) there is a very small allen head screw. Thoughts to keep me from filling me, the car and garage with Halon would be most appreciated. Thank you all for indulging this non-Porsche question.
    If you remove the two small screws holding the
    Aluminum bracket the plunger should slide out.
    You might need to loosen the Allen bolt too
    David - thank you so much for the reply.
